pilot_124 wrote:after the update does not work properly.After starting the program -unfortunately, FLY IS FUN has stopped
Tonio wrote:Hi Pilot 124
Is it still systematically crashing?
Could you provide some more detail :
- Which version of FIF are you using
- Which version of Android are you running
- What is the available RAM of your handset
- Are you storing FIF data on internal device memory, or are you using an SDcard (personally I avoid this, as its a potential source of crash)
More detail you provide, better it is
Thanks and have safe flights
flycarib wrote:
Crash Information
Exception class name: java.lang.StackOverflowError
Source file: ShapeTools.java
Source class: gps.ils.vor.glasscockpit.ShapeTools
Source method: TestEar
Line number: 119
Sentence: at gps.ils.vor.glasscockpit.ShapeTools.TestEar(ShapeTools.java:119)
Stack trace shows a stack overflow error maybe due to recursive calling while processing Airspaces.
Before the sentence that causes the stack overflow error, the stack trace shows the following
sentence repeated more than 200 times:
at gps.ils.vor.glasscockpit.ShapeTools.Tessellate(ShapeTools.java:171)
Viking wrote:Hi Petr and everybody ;)
On map screen, a long tap on the compas (screen customizing), in "Airspaces" in each zoom, if I uncheck "Controlled airspace D", FIF doesn't stop when I move the map..... Best regards. Jean-Pierre. LFFD
Since the last update of FIF, it seems that this airspace D makes FIF Off on some devices
