Today in Tunis, where I leave, being close to Tunis Airport, I tested ADSB-In using Stratux with Fly Is Fun
It works well !!!
Congratulation Petr
For those that already have a Stratux, the way to proceed is the following
1 – Start the Stratux until you get the green light
2 – on your Android device
- Wifi network chose “Stratux” (you may have to disactivate data connection)
There, you can check with your web browser if its work
- Launch Fly Is Fun
3 – within Fly Is Fun, make sure you can use the Stratux
Short press on the compass rose
Then select “Application settings” -> “Preferences” -> “External data source” -> “Wifi” -> “Stratux”
Within “Stratux” page, select “Use it”
Then back to moving map screen, where you can see aircrafts being around
Just great
For those that doesn’t have a Stratux, you can build it your self in less than 1 hour
http://stratux.me/#parts-list for around US$ 150.- or buy one ready to use
http://stratux.me/#pre-built-units for around US$ 240.-
Have fun and send some screen copies
- Screenshot_20190510_141614_gps.ils.vor.glasscockpit.jpg (603.25 KiB) Viewed 34261 times
- Screenshot_20190510_141231_gps.ils.vor.glasscockpit.jpg (626.63 KiB) Viewed 34261 times
