Planning a return flight after treatment abroad
Postby kayward84 » 18 Nov 2026, 02:07
Flight planning gets more complicated when the trip involves treatment abroad. A clinic comparison such as https://medtraveling.com/compare can help with the clinic shortlist, but the return date needs a separate conversation with the treating doctor. I would leave room to change the flight rather than build the whole plan around a fixed departure.
kayward84
Re: Planning a return flight after treatment abroad
Postby nathanbroo92 » 18 Nov 2026, 02:42
I would ask the clinic to put the follow-up schedule in writing before booking the return leg. A price comparison cannot tell you whether a particular departure date is suitable; that needs to be discussed with the treating doctor.
nathanbroo92
Postby kyleadams84 » 20 Nov 2026, 00:06
I would also check where any follow-up blood tests will be done after returning home. AskDocDoc (https://askdocdoc.com/) is a project focused on lab testing in the US; questions about the results and the timing of a flight still need to go to the treating doctor.
kyleadams84
