Rain Radar overlay not working
Postby marpdiaz » 07 Feb 2026, 21:40
No data display on map for Rain Radar. RRA indicator does not start the usual counting. RainViewer app works fine outside FiF.
It is possibly a change in RainViewer API as RV is phasing-out several API resources by jan/fev 2026.
The following alternative sources may deserve a closer look for global coverage APIs: OpenWeatherMap, Rainbow Weather, Tomorrow.io.
Re: Rain Radar overlay not working
Postby marpdiaz » 14 Feb 2026, 12:56
Working fine now.
thank you for the quick fix!
Postby flyyyer » 20 Feb 2026, 10:04
Thank you for the weather link update. I only get the weather overlay now at 40NM or above....is this the new normal now? Thanks Peter G
Postby marpdiaz » 21 Feb 2026, 21:34
Hi flyyyer,
I got the radar rain overlay down to 15 NM arc zoom. Have no overlay display for smaller scales.
I have "rainbow low res" LUT selected in application settings, customize screen.
Postby flyyyer » 27 Feb 2026, 20:45
Thank you marpdiaz.
Although I'm a early and proficient user I'm still stuck on this.
I go to application settings/customise screen then all I get is the screen to the radar application. I'm not sure how to find what you are saying to do.... Thanks for your help.
Postby marpdiaz » 02 Mar 2026, 01:17
Hi Peter,
I am not sure that changing the Color scheme (LUT) will make a difference for all android versions and/or hardware.
In my case (android 11 and 16) it was somewhat helpful - got the overlay down to 25 and 15 NM arc zooming. Still may be tricky because no weather is displayed in higher zoom levels (10, 6, 4 ...).
The Color scheme setting is below the toggle "Show rainfall radar" and just above the "Opacity" ruler setting.
Postby flyyyer » 09 Mar 2026, 18:52
Thanks Marcos.
I set the colour scheme to "original low res" and this allowed rain radar to zoom down to the 15nm level which is better. If you see my other post on "Zoom level not supported" then I understand now that this is all related to this subject. I.e. this message appears when the rain overlay zoom level is not supported. I get this message overlaid all over the map (somewhat ruining the experience) but now at least not until down past the 15nm level. The overlay message warning is not displayed if you turn off the rainfall radar. (but I don't want to do that)
Postby UniformZulu » 08 Apr 2026, 12:35
Hi togethe,
I don't receive at all the rain data anymore.
Any advice?
S23 Ultra... Android 16
I really loved the rain overlay. I am sure the new one is also cool. If I receive it :)
Screenshot_20260408_143201_Rain Viewer.jpg (516.6 KiB) Viewed 19687 times
Screenshot_20260408_143123_FLY is FUN.jpg (629.69 KiB) Viewed 19687 times
UniformZulu
Postby flyyyer » 11 Apr 2026, 09:12
Hi Petr,
Thanks for fixing the rain radar map overlay in the latest version.
Your hard work is much appreciated.
