"the world database is not found"
Postby Alofly » 27 Jan 2019, 17:30
Hello, I have purchased a Sansung Note 9. My previous Galaxy S 7 has died. All the applications were installed when transferring my data from the previous phone. After this I had to download all the maps and databases again.
My problem is that when I start the application it tells me "the world database is not found".
I have tried to download it more than 20 times. I have installed and re-installed everything again but it remains the same.
Any ideas?
Alofly
Re: "the world database is not found"
Postby Tonio » 28 Jan 2019, 15:22
Hi Alofly
Did you install FIF via transfer or via Google Play Store?
I believe it should be installed via Google Play Store
Then check application update from the Play store to make sure that you are using latest FIF version
latest FIF version is version 21.40
If you are not using the latest version, database update could be blocked.
If FIF was properly installed and if you are using latest FIF version, you can still try resetting FIF default config
From the application
“Short press” on Compass Rose
then Application Setting
then Preferences
then General settings
then Factory Default
Have fun and let us know
Postby Alofly » 05 Feb 2019, 13:56
Thanks for your answer
I have done it in both ways.
I think the FIF has problems detecting the memory of the Sansung Galaxy Note 9 (512 Gb).
At the end of precessing the databases sometimes gives an error due to lack of memory space ...
Alofly
Postby Tonio » 05 Feb 2019, 18:31
Hi Alofvly
At least you know where this problem come from
If you have not enough free space on your internal memory (internal hard drive), is not surprising that the application can't write all required informations.
Did you try to clean up your internal memory, erasing couple of Go of data (photo, music, other documents)...
Postby Alofly » 07 Feb 2019, 15:09
Hello Tonio, I think you have not understood the problem. 512 gigabytes would have to be enough. But the FIFno is always able to detect the available space. The IFI may have difficulty reading these great capabilities.
Alofly
Postby kitercuda » 10 Feb 2019, 18:51
Can you write here, when exactly FIF show the message? And please post here screenshot.
Postby milijan » 28 Jun 2019, 10:31
Hi, I have the similar problem. I used Fly is FUN more then one year on my Huawei T3 tablet without any problem. I had two months without subscription and with no database update. I bought subscription for the next year at 18th June and from this time I am not able to import Navigation Database Data for any country (I tried Poland, Hungary, Croatia, Czech Republic, Slovakia, Italy). Import is running and end without error (see attached pictures), but after restart program show "No Naviagation Database Found". Import of the terrain is without any problem. I tried to fix it: 1. Uninstall and Install program, 2. Uninstall program, manually delete program directories, install program, 3. Factory reset of the tablet and Install program. Any from these steps solved it. I reset default config to, but no success. Version of the FIF is 22.50. Thanks for help. Milan
milijan
Postby milijan » 28 Jun 2019, 10:36
Import Navigation Database End.jpg (280.38 KiB) Viewed 19611 times
Import Naviagation Database.jpg (250.07 KiB) Viewed 19611 times
Naviagtion Database Not Found.jpg (233.7 KiB) Viewed 19611 times
Pictures for previous problem. Milan
milijan
Postby kitercuda » 08 Jul 2019, 17:41
Try to update to the last version: 22.60
