How is the marker sound created?
Postby jonewborg@telia.com » 06 Sep 2017, 18:18
I wonder how the sound when passing a marker beacon is created?
Is it from position or from the real marker?
jonewborg@telia.com
Re: How is the marker sound created?
Postby Tonio » 06 Sep 2017, 20:25
You will probably find the info in FIF
Short tape on compass rose -> Application setting -> Preferences -> Marker beacons
Let us know your conclusion :)
Postby Desmond » 07 Sep 2017, 05:40
jonewborg@telia.com wrote:I wonder how the sound when passing a marker beacon is created?
It's created thru automatically deriving (calculations) a zone theoretically projected out from the runway. When your GPS position conforms, the sound plays.
To be sensing a real marker, your phone or tablet would need to be shipped with and aviation receiver within it. So . . . ?
Desmond
Postby marpdiaz » 08 Sep 2017, 11:38
FiF calculates virtual spot regions appropriate for outer, middle and inner markers. The corresponding audio is played while your GPS position is located within the spot.
clear skyes,
Postby kitercuda » 10 Sep 2017, 10:08
Exactly :-)
FIF has database of the real markers. If you are overhead marker (GPS position), FIF plays the marker sound.
FIF can play also the marker sound, even if there are not real markers. FIF creates the virtual ones.
The settings is here: Menu/Application settings/Preferences, Marker beacons.
But ILS or RWY must be selected as a next WPT.
Postby navvegante » 14 Feb 2018, 05:51
Would be great if the Marker Beacon sound can be customize.
navvegante
Postby kitercuda » 05 Mar 2018, 18:41
I will implement customizing of all sounds...
Users browsing this forum: No registered users and 18 guests
