View PDF broken link ATM in Aus
Postby Desmond » 05 Sep 2017, 22:58
Please be advised. Today, when I touch the 'PDF' the app searches the wrong place.
e.g. I touch PDF while the YPMQ info box is open & I get a diag box saying: "PDF file is not available . . . . YB/YPMQ"
So it seems to always be assuming the wrong direct parent folder.
Desmond
Re: View PDF broken link ATM in Aus
Postby Desmond » 07 Sep 2017, 05:42
This is somewhat Urgent
Desmond
Postby Tonio » 07 Sep 2017, 22:32
You probably chose
- "PMQ" Port Macquarie
instead of
YPMQ PQQ "Port Macquarie"
Try zooming on the map.
If you select YPMQ PQQ "Port Macquarie" it should work
Postby kitercuda » 10 Sep 2017, 10:25
If you are want to use PDFs, you must download them (via FIF or manually)
- When you download PDF via FIF, all PDFs are located at .../GPS_ILS_VOR/PDF_system/country code/ICAO
- All user PDFs must be located at .../GPS_ILS_VOR/PDF/country code/ICAO
If you want to create all folders for some country:
- Open Nav database
- Open folder World database
- Long tap ath desired country
- Tap at Create PDF folders at context menu.
Postby Desmond » 13 Sep 2017, 03:34
Okay,
I've been DLing PDFs manually for over a year quite successfully. It seems you have changed the folder ladder structure recently. I must have missed that in the update announcements.
I must really behind the times because the folder named 'YM' threw me. I really thought Australia's [country] ICAO code was 'Y'.
I'll have a mess around and get it going again, thanks :)
Desmond
Postby kitercuda » 13 Sep 2017, 11:08
Sorry, I realized, there were some changes. Each nav database item now has country code. If country code is filled, it is used for PDF...
Postby Desmond » 23 Sep 2017, 04:37
Okay, I got it working on 13 Sep. :D
Please understand, I think you should correct the 'country ICAO' descriptor within the script that governs search criteria. (e.g. upon tapping 'PDF' from map screen dialog box).
The app currently requires all Australian PDFs be put in a folder called 'YM'. I know you will agree that this is wrong as a cursory check of any of our [Australian] NAV items clears away any confusion.
We [now] know the storage folder should be labelled 'Y' in accordance with our country's ICAO discriptor.
However, I do not feel this is urgent anymore.
Thanks again.
Desmond
Users browsing this forum: Baidu [Spider] and 10 guests
