Schemes of the Airports (PDF) and RNK 2013 07 AIP
Re: RUSSIA PDF AP and RNK 2013 07 AIP
Postby Onuff » 04 Nov 2013, 11:25
http://yadi.sk/d/MdA-JRjNC6sgi
this file or that that in a forum.
I open points, I press import I choose the file. occurs nothing.
in mother Earth it opens
Postby kitercuda » 04 Nov 2013, 20:22
FiF can work only with files, which contain data.
Your file does not contain any data - just links to data.
If you unzip file, you get doc.kml and if you look inside, you get something like this:
<?xml version="1.0" encoding="UTF-8" ?>
- <kml xmlns="http://www.opengis.net/kml/2.2">
- <NetworkLinkControl>
<linkName>ВП РФ 07.03.2013</linkName>
- <linkDescription>
- <![CDATA[
Структура воздушного пространства Российской Федерации.<br>
Введена в действие с 28.06.2012г.<br>
<br>Copyright © 2011 <a href="http://www.aopa.ru">АОПА-Россия</a>
</linkDescription>
</NetworkLinkControl>
- <Document>
<name>ВП РФ 07.03.2013</name>
- <NetworkLink>
<name>Зоны и районы</name>
<description />
<visibility>1</visibility>
- <Link>
<href>http://aopa.ru/maps/199_v02.kmz</href>
</Link>
etc....
So if you want to import airspace, you must download this:
Запретные зоны
http://aopa.ru/maps/204_v02.kmz
Опасные зоны
http://aopa.ru/maps/203_v02.kmz
Зоны ограничения полётов
http://aopa.ru/maps/212_v02.kmz
NOTAM
http://aopa.ru/maps/notam_v02.kmz
Воздушные трассы
http://aopa.ru/maps/vt_v02.kmz
Местные воздушные линии
http://aopa.ru/maps/mvl_v02.kmz
Аэродромы
http://aopa.ru/maps/ad_v02.kmz
Специальные зоны
http://aopa.ru/maps/sz_v02.kmz
If these data are up to date, I can work for adding them to database for easy using them. It would be not easy (I guess 2 weeks of working), because of different format, but possible and I woudl need your help (testing, distingish what is important etc.)
Postby Onuff » 10 Nov 2013, 18:29
I understood that it for the file
I didn't know that such happens
I am ready to help
Postby Onuff » 12 Nov 2013, 13:18
Postby Onuff » 08 Jan 2014, 13:37
Schemes of the Airports of Evropa, Russia and CIS (Jeppesen, cycle 1401)
Author: Jeppesen
http://yadi.sk/d/p5Gm_PavFeazF
Postby Onuff » 17 Jan 2016, 10:30
Запретные зоны
Опасные зоны
Re: Schemes of the Airports (PDF) and RNK 2013 07 AIP
Postby Onuff » 23 Jan 2016, 14:15
Petr
What can I do?
Postby Onuff » 07 Feb 2017, 20:08
От Константин Константина
Схемы Аэропортов России и СНГ (Jeppesen, цикл 01-2017)
https://m.vk.com/doc221798070_441493486 ... 8765087fc1
Postby kitercuda » 18 Feb 2017, 21:08
Hi. Sorry I forgot to answer...
No open 203_v02.kmL in FIF?
Because FIF do no reckognise this format. It is quite complicated. There are scripts in the file.
Try one thing:
- Rename 203_v02.kmz to 203_v02.kmz.zip
- Unzip file- you get doc.kml
- have a look inside doc.kml
Write me email, which data are you missig.
