Heliports!?
Heliports!?
Postby hugosilverio » 23 Dec 2014, 11:40
Hello Petr!
After a while without using FIF (changed my cellphone), i went for a flight this morning, and noticed that pretty much ALL Heliports in Sao Paulo (brazil) are gone!
I went to screen preferences and enabled HELICOPTER under waypoints, and no success. i remember it had all of them! i used it pretty much all day.
what happened to them? (im using the latest navdata, left it downloading overnight, took 2:30 hours to finish everything)
hugosilverio
Re: Heliports!?
Postby hugosilverio » 25 Dec 2014, 22:19
No-one???
hugosilverio
Re: Heliports!?
Postby marpdiaz » 26 Dec 2014, 20:32
for diagnostic purposes:
just downloaded the Brazil db and airports came out right.
samsung tablets g-70 and tab3 running android 2.3 and 4.4
Re: Heliports!?
Postby hugosilverio » 27 Dec 2014, 13:27
airports shows correcly.
the problem is that all HELIPORTs disappeared.
Near SBMT we had hundreds of HP... now there are none.
hugosilverio
Re: Heliports!?
Postby kitercuda » 27 Dec 2014, 16:21
Do you have checked Heliports, When importing the world nav database? Default is unchecked!
Re: Heliports!?
Postby hugosilverio » 28 Dec 2014, 00:25
i did.
i also tested on my android laptop. (installed android on it instead of windows. its awesome! downloaded and converted navdata in 8 minutes!)
None of them shows the heliports.
even going on screen setup, and enabling helicopter options.
hugosilverio
Re: Heliports!?
Postby Johannes » 15 Nov 2016, 21:18
Still no heliports in São Paulo. When will they be there?
Johannes
Re: Heliports!?
Postby Johannes » 27 Nov 2016, 18:54
I just created the REH SÃO PAULO acc to AIC N 17/15 (Special Helicopter Routes SÃO PAULO).
Please feel free to use.
Still missing the São Paulo Heliports though. Hope you can add those for the next version.
Corrected file (altitudes were inverted, some selected heliports included)
REH SAO PAULO AIC N 17 15_Rev1.zip
(22.21 KiB) Downloaded 864 times
Johannes
Re: Heliports!?
Postby MacRob » 20 Mar 2017, 01:07
Hello.
Just tried to add a heliport after updating app to latest version. Didn't work. The H symbol doesn't display on the map. If i change properties to Glider the G symbol is displayed on the map. I can't figure out why H symbol does not get displayed. On review no Heliprts in the area are displayed. I don't see a preference to hide H symbols. Confirmed heliprts are downloaded and added heliport seems entered correctly. Is there a solution for this condition?
Rob
MacRob
Re: Heliports!?
Postby kitercuda » 24 Mar 2017, 16:58
I am at the holliday. I will have a look at it at the begin of April.
