The problem with the route
Postby Andrzej18g » 20 Sep 2016, 11:37
I have a problem with creating routes.
ENTER key (upper right corner ) is not active.
Andrzej18g
Re: The problem with the route
Postby kitercuda » 25 Sep 2016, 17:32
Can you describe it more? Or post some screenshots?
Postby Andrzej18g » 26 Sep 2016, 16:55
I add 2 screenshots during route planning
Key Enter is still not active.
I cant save the name of route. Enter is not active
Andrzej18g
Postby Tonio » 26 Sep 2016, 18:43
Did you try to plane a route with at least 2 WP ?
As soon you have 2 WP, the OK button should be activated
It's th case on my device
I assume a route with only 1 WP isn't a route
Postby Andrzej18g » 01 Oct 2016, 12:10
I can not add another point, because I can not confirm the first. When I try to add another replaces an existing item.
Andrzej18g
Postby Viking » 01 Oct 2016, 21:51
You don't need to confirm the first waypoint. The Enter key is used for a route with 2 waypoints minimum.
To add an second waypoint, you click on the "world map" key (up and left), Image
a tap on a waypoint, on map, and then a tap on "route" key, and after, at the end, to come back in route menu, you confirm with the green check (you can see the number of waypoints).
After, you write the name of the route and now, it is possible to save the route. (Enter key)
You can also add with a tap on the the "+star" key (on the right of the "world map" key.
Have a good sunday.
Jean-Pierre, LFFD.
Viking
