Missing airspace
Missing airspace
Postby flyyyer » 28 Mar 2016, 20:37
Hi Petr,
Could you tell me how to put back some airspace that recently vanished? I have checked many devices and all are missing it. This particular airspace still exists and is on charts. There may be more missing (worrying not to know if and where to check) but this particular bit is just below the Manchester UK TMA. In the past I have never noticed any errors at all....lots of flights and simulated flights to check my routes.
Could you explain the mechanics to how the FIF airspace is generated and is kept up to date...
Re: Missing airspace
Postby kitercuda » 30 Mar 2016, 10:11
Hi Peter, which airspace are you missing?
Airspace database update is doing my contributor.
Postby flyyyer » 30 Mar 2016, 19:17
This is an old Navbox data(08) but it shows the 2 areas at least that are missing. I need to check on a later chart to be up to date on this area.
I realised these are missing because I fly up to Blackpool through this airspace. Thanks Peter G
Postby flyyyer » 14 Apr 2016, 08:34
Hi Petr,
The above airspace is still missing.... There are few other bits missing around this area also. How is the airspace updated/monitored/checked for the UK. Quite important for this to be reliably correct I think. Can I help? Regards Peter G
Postby flyyyer » 18 Apr 2016, 09:55
Seems to be Class A airspace that is missing. North and south Wales Some of it is part of Airway N864. This reduces into Class D airspace top and bottom around BCN and WAL VORs But some other bits as well.
Could really do with fixing asap....
Users browsing this forum: Majestic-12 [Bot] and 3 guests
