Import .gpx file as ROUTE always fails
Postby Laotse » 04 Apr 2014, 04:26
Dear all,
whenever I try to import a GPX file containing routing information, FiF is processing the data, but the result always leads to 0 import.
Example: I like to use SKYVECTOR for fast and convenient flightplanning. Via the application "INavCalc" I convert the plain link from skyvector into a GPX file.
Those files I cannot import into FiF. But in general that happens also with other sources of GPX files.
What do I miss here?
Kind regards,
Laotse
Laotse
Re: Import .gpx file as ROUTE always fails
Postby kitercuda » 07 Apr 2014, 19:00
Hi, ZIP your files and upload here to check them...
Postby Laotse » 08 Apr 2014, 08:40
Hi Pitr,
I attach some examples, which were generated via INavCalc.
Cheers,
Laotse
route.zip
Examples
(1.66 KiB) Downloaded 980 times
Laotse
Postby kitercuda » 08 Apr 2014, 15:28
Thanks Laotse,
There is a problem, route has no name.
Next upgrade will solve it. In case of no name, application add an automatic name.
Postby Laotse » 15 Apr 2014, 06:54
That explains it. Thank you very much, now it works very well!
As always, GREAT SERVICE !!!!
Thank you,
Laotse
Laotse
