Postby kitercuda » 22 Jan 2014, 07:39
What is diplaying LT value on FIF screen (if you do not see it, customize screeen). Is it correct?
Postby flyyyer » 22 Jan 2014, 22:54
Not sure if this question was for me or what definitively you were asking but...
All of the LT options are correct (LT ETAs, LT etc) except for the DTA.....LT 24 This adds 1 hr on to your
input set time. This would be correct were we to be on British summer time, we are presently on winter time which is same as UTC.
Postby flyyyer » 22 Jan 2014, 23:01
Thinking further... actually if we were in future on British summer time then you wouldn't add the extra hour either as I would select the local time into the box.....
PJ
Postby kitercuda » 24 Jan 2014, 05:54
I will have a look at LT DTA, why this is different...
Edit: I am not at your timezone to check it, but I have made some changes. I hope version 14.20 will solve problem with the local time DTA.
Postby Onuff » 03 Feb 2014, 20:14
New artefacts))))))
Postby kitercuda » 04 Feb 2014, 13:12
Beautiful :-)
How did you do it?
Postby Onuff » 04 Feb 2014, 18:43
Quick zoom+- 2 finders
Postby Onuff » 09 Mar 2014, 14:56
Inter route (fast input)---->>>>
UUWW NE BD BANAL UUEM
Postby kitercuda » 09 Mar 2014, 20:32
Good idea,
but what to do, if you have for example multiply VRPs. Czech airports have Alfa, Bravo, Sierra etc. There are in different folders, but if you write it, how to select the right WRP?
Postby Onuff » 14 Mar 2014, 20:36
how to unite bases from several devices?
