Broadcasting and receiving position via mobile data.
Postby kitercuda » 11 Jan 2014, 17:51
I am implementing now broadcasting your position to FIF server via mobile data and receiving positions from server.
Broadcasting:
- User can enable/disable broadcasting. Broadcasting can be public or private (only FID user who knows group ID can access private data)
- There are stored only the last position at the FIF server, no history.
Receiving:
- User can select, which groups wants to see (if he knows their group id)
Question:
Is there anybody who would implement simple web application? Only map with the aircrafts from FIF server.
Sample of http request:
www.funair.cz/flyisfun/position/getposi ... a;FIF;Test
Result is the XML file. See attached file...
fif.zip
(543 Bytes) Downloaded 1165 times
Re: Broadcasting and receiving position via mobile data.
Postby bitbrusher » 11 Jan 2014, 23:27
Petr
There is a program called TRACCAR - http://www.traccar.org/ - (among others) that tracks cars. I use it.
It understands a bunch of protocols. Some of them are very simple.
If you manage to implement one of those protocols you can track the acfts in a blink.
Just point FiF to my server. I can create an account for you.
cheers
bitbrusher
bitbrusher
Postby Onuff » 12 Jan 2014, 11:43
This is programme used function monitoring. Netradar
http://www.mapnav.spb.ru/site/
Postby flyyyer » 16 Jan 2014, 17:56
I use another app to do tracking which works well "Real Time GPS Tracker" will it work like this but from within FIF? Great if it does.... Peter G
Postby kitercuda » 19 Jan 2014, 07:54
Look at the picture :-)
It is working - beta version. We are trying to add some ADS-B network, communicating with owners...
Postby marpdiaz » 19 Jan 2014, 09:34
looks pretty nice!
Our region is well sampled by ads open databases e.g. flightradar24.com
It may be possible to download streams from them, eventually.
best,
Postby kitercuda » 19 Jan 2014, 11:23
We contacted people from FR24, but they do not want to share data. lIt is possible to access their data, but without FR24 permission I do not want to do it.
Postby kabong.steve » 20 Jan 2014, 00:19
Hi Petr,
Have you thought about integrating to an existing environment like this, rather than setup another site
http://www.glympse.com/
You'd have to use their API's directly from Android.
Just a thought
Steve
kabong.steve
Postby kitercuda » 20 Jan 2014, 10:28
I think, FIF have to display only aviation data. So I am trying to connect to some ADS-B site...
