App continues to run
Postby flyingboy » 01 Dec 2013, 17:11
First, great app. Saving me £££ compared to others.
Currently running on a nexus 7 (2013) android 4.4 (I noticed this before upgrading from 4.3).
For some reason, app continues to run even though I 'close' it.
Running the latest 13.11 but noticed problem about 3 weeks ago.
Currently using a task manager to kill n the app.
Any one else having this issue, or have I changed a setting and just can't find it now.
Michael
flyingboy
Re: App continues to run
Postby kitercuda » 01 Dec 2013, 18:11
Did you use Menu/Close?
Postby flyingboy » 01 Dec 2013, 22:24
Yes, I always use the correct method, menu/close.
The app is still showing.
I initially thought I was simply seeing 'previously used apps' but I noticed the battery was continuing to drain quickly after a flight sometime in November.
I confirmed app is actually running by using a task manager showing all running apps.
flyingboy
Postby kitercuda » 01 Dec 2013, 22:53
Hmm, there were not changes in finishing function...
Postby flyingboy » 01 Dec 2013, 23:44
I have been playing around with a number of different launchers for the android.
If no one else has reported anything, I will do a full reset and start fresh.
I noticed another app this evening when using its 'close' within the App, it actually crashes the App.
It may be a week or 2 before I reset, but will advise if it helps our not.
Thanks for taking time to reply
Michael
flyingboy
