Graphics
Re: Graphics
Postby Onuff » 30 Sep 2013, 17:54
vitaliksh777 wrote:Hi kitercuda!
All the same, it would be better if done as requested Onuff!
Update interval and set it to 3 seconds - it is not readable, analyze flight for two or one point seriously!
All I asked for - nothing has been done as it should. My pilots may lose the desire to buy this app. About anything else to ask - simply do not make sense! I have a lot of pilots, but without me, no one will buy this program. I wanted to show in the picture look like these points - but could not download. Feeling - there is no interest to new customers.
how many pilots the appendix will buy???))))))
Re: Graphics
Postby kitercuda » 30 Sep 2013, 18:08
Good question to vitaliksh777, but
I do not care. I have several business companies, programming is just my hobby :-). At this time, I am kite-surfing at Mauritius ;-)
Edit: Switch is done, next upgrade...
Re: Graphics
Postby bitbrusher » 01 Oct 2013, 19:35
Petr
I may be doing something wrong but if I slide the desity bar from 10 to 58 I see no sigificant difference in screen.
It is like FiF is not connecting the point with doted lines.
This is a screenshot with dot density bar at 10
an this is with dot density at 58
help, please?
bitbrusher
bitbrusher
Re: Graphics
Postby kitercuda » 02 Oct 2013, 04:19
This is MAX density. So if you have not enough GPS fixes, density can be similar. Run application press Menu/App settings/Preferences then find Logbook/Update interval and set it to 3 sec.
Version 12.47 has track switch (dot or line) when customize screen.
Re: Graphics
Postby vitaliksh777 » 02 Oct 2013, 17:38
Hi kitercuda!
Version 12.47 has track switch (dot or line) when customize screen - was not able to include line!
Tell me where the switch.
Thanks for the line.
I look forward to the promise of the figures in the second ETA.
vitaliksh777
Re: Graphics
Postby vitaliksh777 » 02 Oct 2013, 17:41
Для Onuff
Можно и на русском - много.
vitaliksh777
Re: Graphics
Postby kitercuda » 02 Oct 2013, 19:26
What you exatly want?
Re: Graphics
Postby vitaliksh777 » 03 Oct 2013, 15:08
kitercuda wrote:What you exatly want?
Hi kitercuda!
I apologize for the incorrect translation.
You promised in October to do instead of points (seconds) digits.
Thanks for the switch!!!
vitaliksh777
Re: Graphics
Postby kitercuda » 03 Oct 2013, 20:02
I dot know, not easy (values rectangle are not designed for 6 digits) and I have a lot of work on another parts of application.
Menu/App settings /Position info - there are seeconds...
Re: Graphics
Postby vitaliksh777 » 05 Oct 2013, 06:29
kitercuda wrote:I dot know, not easy
Good! We'll wait.
vitaliksh777
