Graphics
Re: Graphics
Postby vitaliksh777 » 25 Sep 2013, 18:29
Hi kitercuda!
Flight track displayed like dots (not line) - Need to return back (with line), just can not see Flight track.
No one wants to be updated!!!
Or choose the display line - like dots or full line!
There is a bug with setting the time zone. Setting a different time zone, it does not change. This bug only on the tablet.
vitaliksh777
Re: Graphics
Postby kitercuda » 26 Sep 2013, 04:11
I just have made optionn - dot density, so if you need more dots, you can select and track will looks like line...
Next upgrade...
Re: Graphics
Postby Onuff » 26 Sep 2013, 17:49
Ok - made options
_________
Re: Graphics
Postby flyyyer » 26 Sep 2013, 18:17
Great... Yes I preferred the original line also
Re: Graphics
Postby flyyyer » 28 Sep 2013, 07:34
I still prefer the original full line for looks compared to a full density of dots. (I imagine some prefer the dot trail though)
Can the full slider position turn the full line back on, just like your original line if possible?
Re: Graphics
Postby kitercuda » 28 Sep 2013, 09:03
Go to Preferences, Logbook, Update interval and set it to 3 seconds.
Re: Graphics
Postby vitaliksh777 » 28 Sep 2013, 16:30
Hi kitercuda!
All the same, it would be better if done as requested Onuff!
Update interval and set it to 3 seconds - it is not readable, analyze flight for two or one point seriously!
All I asked for - nothing has been done as it should. My pilots may lose the desire to buy this app. About anything else to ask - simply do not make sense! I have a lot of pilots, but without me, no one will buy this program. I wanted to show in the picture look like these points - but could not download. Feeling - there is no interest to new customers.
vitaliksh777
Re: Graphics
Postby kitercuda » 29 Sep 2013, 08:45
If you set Update interval to 3 sec and Max track dot density to max possible value screen looks like attached pictures. When you export to KML and import to Google Earth, you can see flight track in 3D (with altitudes). If it is still not enough, I will add to Customize screen track switch: dot x line...
Re: Graphics
Postby vitaliksh777 » 29 Sep 2013, 17:21
Hi kitercuda!
Analyze the landing is not interesting. Need analysis of passage points for aerobatics, speed of more than 1000 km / h on ekrane 1 or 2 points. Need a solid line.
vitaliksh777
Re: Graphics
Postby kitercuda » 29 Sep 2013, 17:50
OK, I will make switch.
