Waypoints, edit, export and import
Postby francojb » 17 Apr 2013, 01:16
Is there a way to export waypoints in a text file??
Is there a way to edit data to a group of waypoint at the same time??
Because I would like to edit the same data in a group of waypoints and check and correct some coordinates.
francojb
Re: Waypoints, edit, export and import
Postby kitercuda » 17 Apr 2013, 07:33
1. You can export them in internal or KML format
Long tap at the folder which you want to export and select Export or open folder and press Menu/Export
2. Group editing: Long tap at the folder which contains nav items which you want to edit and select Change all items inside. This option is improved in version 10.80 (will be available until the end of this week)
Postby francojb » 22 Apr 2013, 13:23
Thanks for answering!!
I´ve just knew those options but they are not exactly for what I need to do...
One point is I found some coordinates, of airports specially, that are not right, I have a list of the correct coordinates and I think that is easier to check all the coordinates together in a text file for example. I don´t know if there is other way. And the other point, not much important, is that I was needing to change a data of a group of waypoints in a folder but not to the whole folder... and in a text file it will be easier...
Thanks!!
francojb
Postby kitercuda » 23 Apr 2013, 11:24
There is some hidden option for exporting txt file.
I will think how to enable it to users.
Postby francojb » 27 Apr 2013, 23:25
Ok Thank you!!
francojb
Postby gbuzare » 13 Jun 2013, 15:45
due to the last update, it seems that VRPs are no more displayed on Map.
gbuzare
Postby kitercuda » 14 Jun 2013, 12:27
Hi Gilles
There were not changes about VRP.
I haVe checked it and I have all VRPs like in previous version.
Try this:
- Long press compass rose to customize screen
- look if is checked TWPT and VRP (both must be checked)
- For each zoom level you have seaparate settings!
Postby gbuzare » 14 Jun 2013, 13:50
OK Petr,
That works correctly. I don't know what happened !
thanks.
About VRPs in CTR LYON : It is my daily Flying area.
custom VRPs :
About LFHV, we have a special night VFR pattern, with spécifics VRPs.
I can also communicate the élements of GLS for RWY36L and RWY18R.
I can give you these infos if you are interested in.
I have tested them at night (VFR) because I use a GPS WAAS sensor (via bluetooth).
I confirm that the difference between ALT GPS and ALT altimeter is less than 6 ft !
I have also tested terrain info in the area and it fit very well.
gbuzare
Postby marpdiaz » 19 Jul 2013, 13:40
Hi Petr,
I imported a gpx file with many (2700) waypoints. They do appear in the maps and everything works fine. Then I changed all at once from wpt -> apt using the long tap options on their directory. After that, they take a long time to list when i want to select one, and sometimes the code crash. It stuck with the message "filling list box". This operation is very fast in other folders with comparable number of items.
I hv submitted a report so you may access the error codes.
I got the same problem importing a kml file.
best,
Postby kitercuda » 20 Jul 2013, 08:33
Please, can you send me your files.
When you have a lot of APT in one folder, there can be problem with long filling :-(.
When filling list box, application checks each APT, if exists VHF (in the VHF table) for this item. It is the same as TWPT.
