Graphics
Graphics
Postby Eliseo » 22 Mar 2013, 16:42
When I import data only accept the "-" sing
Is it possible to introduce signs as "/, *, :" etc.?
good flights.
Eliseo
Re: Graphics
Postby kitercuda » 27 Mar 2013, 16:54
Please, send me your file for import. I will check it out.
Re: Graphics
Postby Eliseo » 28 Mar 2013, 10:11
Import
Eliseo
Re: Graphics
Postby Eliseo » 28 Mar 2013, 10:14
This is the problem, if you want I send you the attached file in GPX.
Eliseo
Re: Graphics
Postby kitercuda » 28 Mar 2013, 18:03
Hi, it is enough.
Application some charcters becuse they are reserved for future use.
I will enable / in the next upgrade
Re: Graphics
Postby Eliseo » 29 Mar 2013, 10:08
Thanks.
Eliseo
Re: Graphics
Postby kitercuda » 31 Mar 2013, 09:40
Version 10.7 enables /
Re: Graphics
Postby vitaliksh777 » 04 May 2013, 17:09
Very need to display the time with seconds in LT and ETA. Or the possibility of the most dobovlyat them on the menu. If you do what my pilots will buy you this program. Otherwise, be glad.
vitaliksh777
Re: Graphics
Postby kitercuda » 04 May 2013, 18:31
You can see ETA HH:MM:SS here: Menu/Tools and info//Position information.
I can add local time...
Re: Graphics
Postby vitaliksh777 » 05 May 2013, 08:09
This is the only navigation software for android where time is calculated. Really like accurate readings and the absence of inertia. In flight, the hands are busy and you can not press the screen. So please make the ability to display the time with seconds ETA and(or) LT. If you are interested in new buyers are asking for help. This detail is very important to us. Without my permission, my pilots do not buy this program. We'll wait. I hope for cooperation.
vitaliksh777
