ILS navigation
ILS navigation
Postby airbornephoto » 23 Apr 2012, 11:16
There is a green line that extends in both directions out from a small circle at the far end of the runway which seems to be oriented to true north. This does not jive with the compass deviation needle. It should be the same so both line up together.
airbornephoto
Re: ILS navigation
Postby kitercuda » 24 Apr 2012, 07:25
Green line is the localizer course and small circle is the localizer.
I will check your question about deviation today or tomorrow.
Edit:
In application is bug. When directions are set to magnetic, green course line is not good. I will repair it in the next update.
Thanks.
Re: ILS navigation
Postby kitercuda » 01 May 2012, 07:58
I just uploaded version 5.21. It solves this problem...
Re: ILS navigation
Postby Eliseo » 04 Mar 2013, 09:51
It is possible to have more ILS scales and make it less sensitive? In short final of the glide slope path is suddenly very nervous going up and down, in other words make wider the cone approximation.
thanks.
Eliseo
Re: ILS navigation
Postby kitercuda » 06 Mar 2013, 13:19
I do not konw - I will thing about it, because application try to simulate real ILS. Max deflection of GS and LOC are given...
Look at the picture.
Re: ILS navigation
Postby kitercuda » 06 Mar 2013, 13:27
What GS angle are u already using?
Re: ILS navigation
Postby Eliseo » 07 Mar 2013, 12:00
I understand.
In my ULM field the is a electric tower I need 4º or 4.5 º.
thanks
Eliseo
Re: ILS navigation
Postby kitercuda » 08 Mar 2013, 07:07
Version 10.4 have always maximal Glide sloppe angle deflection 0.72 degree. Then GS indicator was out of range. So in range was GS angle from 2,28 till 3,72 degree.
Version 10.5 will have max. "in range" glide slope angle deflection 0.24*GS angle.
So if GS angle is:
- 3 degrees - max "in range" deflection is 0.72 up or down
- 4 degrees - max "in range" deflection is 0.96 up or down
- 5 degrees - max "in range" deflection is 1,20 up or down
etc.
This settings is like real ILS.
For ILS approach is much better device with barometric sensor. Barometric altitude is more accurate!
I am working on bluetooth barometric sensor. i hope it will ready in the middle of this year.
Re: ILS navigation
Postby Breitling » 08 Mar 2013, 10:43
kitercuda wrote:I am working on bluetooth barometric sensor. i hope it will ready in the middle of this year.
Which sensor is this?
Breitling
Re: ILS navigation
Postby kitercuda » 08 Mar 2013, 10:52
Some devices have barometric sensor, for example Samsung Galaxy S3.
On company in Germany is developing barometric sensor which will be able to connect to FLY is FUN via Bluetooth.
