Dear Farly / Děkuji
According your screen copies, your maps "Bossy_2017_v3ZL1-11, CartaBossy_2018_ZL2-11, VFR1-ZL7-11" are in the right folder and in the right format. That's why you see them in green.
Jump directly to step 3 to select the map you like to use in background1 - “Import” function requires an active internet connection
Import function allows i) accessing remote Fly Is Fun server, ii) displaying data/maps available on Fly Is Fun remote server, iii) importing data / from it.
Without Internet connection, you can’t connect to remote Fly Is Fun server, that for it is absolutely normal to get the “Connection error” message.
Once data/maps are imported and properly installed on your device, you don’t need Internet connection to use them. You just need to receive satellite position signal / GPS
2 – Where should be installed a map to use with “Fly Is Fun” and in which format
2.1 - Map format
Fly Is Fun allows using RMapSQLite format (zoom level 6 to 14) map.
The map being i) a map downloaded from Fly Is Fun server (cf1), or ii) map you generated with MOBACS, SAS Planet….
2.2 - In which folder
The map need to be in “RMapSQLite” folder, that is in “Maps” folder of “GPS_ILS_VOR” folder (GPS_ILS_VOR /Maps/RMapSQLite). “GPS_ILS_VOR” is Fly Is Fun application folder
3 – To select the map to use with Fly Is Fun
- Start Fly is Fun and go to that “Moving Map” screen
- 1-Moving_Map_Screen.jpg (66.03 KiB) Viewed 6382 times
- Being on “Moving Map” screen, long press anywhere on the map part (grey area, if there is no map displayed in background).
- An 8 buttons palette popup.
- 2_Map_Selection.jpg (78.09 KiB) Viewed 6382 times
- Select “Map selection” (bottom right)
- Map(s) that is available, in the right format, in “RMapSQLite” folder is/are displayed
- 3_List_of_available_maps.jpg (60.32 KiB) Viewed 6382 times
- Select the map to use.
Advice: Always download to the “World 6-9”.
If having selected a map, the background remain greys, selecting the “World 6-9” allow easily to check/see where the GPS is positioning your aircraft
Does it solve your problem
Bons vols
Cher Farly / Děkuji
D'après vos copies d'écran, les cartes "Bossy_2017_v3ZL1-11, CartaBossy_2018_ZL2-11, VFR1-ZL7-11" que vous avez générées sont dans le bon dossier et au bon format, raison pour laquelle vous voyez leurs noms en vert.
Passez directement à l'étape 3, pour sélectionner la carte à utiliser,
1 - La fonction "Importer" nécessite une connexion Internet active
"Importer" permet i) d'accéder au serveur distant Fly Is Fun, ii) d'afficher des données / cartes disponibles sur le serveur distant Fly Is Fun, et iii) d'importer des données / à partir de celui-ci.
Sans connexion, pas d’accès au serveur. Il est donc normal que le message « Erreur connexion » s’affiche.
Quand les données / cartes ont été importées et correctement installées, vous n'avez plus besoin de connexion Internet.
Il faut juste capter la position satellite GPS
2 – Où installer une carte à utiliser dans Fly Is Fun et dans quel format
2.1 - Format
Fly Is Fun permet d'utiliser des cartes au format RMapSQLite (zoom level 6 à 14).
La carte est i) soit une carte importée du serveur Fly Is Fun, ou ii) soit une carte générée avec Mobacs, SAS Planet…
2.2 - Dans quel dossier
La carte doit être dans le dossier "RMapSQLite", lequel est dans le dossier "Maps", qui se trouve dans le dossier "GPS_ILS_VOR" (GPS_ILS_VOR / Maps / RMapSQLite). "GPS_ILS_VOR" est le dossier de l'application Fly Is Fun
3 – Sélectionner la carte à utiliser par Fly Is Fun
- Lancer Fly Is Fun et afficher l'écran "Moving Map"
- L'écran "Moving Map" étant affiché, appui long sur n'importe quelle partie de la carte (zone grise, si aucune carte n'est affichée en arrière-plan).
- Une palette de 8 boutons s’affiche.
- Appui sur "Sélection de carte" (en bas à droite) affiche la liste des cartes installées dans le dossier "RMapSQLite"
- Là vous pouvez sélectionner la carte à utiliser.
Conseil
Toujours télécharger la carte "World 6-9" en plus de votre carte.
Si ayant sélectionné votre carte, un fond gris s’affiche, en sélectionnant la carte "Monde 6-9", vous pourrez voir où le GPS positionne votre appareil…
Ceci règle-t-il votre problème
Bons vols
