Import Logbook
Import Logbook
Postby japax » 02 Apr 2015, 20:17
I would like to copy my old logbook data into the FiF Logbook.
What file types I can import? I found the export section in the
manual but nothing about import.
japax
Re: Import Logbook
Postby kitercuda » 04 Apr 2015, 05:38
There are two ways:
1.
- Open logbook in your old device
- Press Menu / Export
- Select Logbook (exported will be: logbook, pilots, aircrafts)
- Copy file to your new device
- Open logbook in your new device
- Press Menu / Import
- Select file
2.
- Copy file logbook.db to your new device. There are stored all logbook data (logbook, pilots, aircrafts)
File is placed at GPS_ILS_VOR/database
Re: Import Logbook
Postby japax » 04 Apr 2015, 12:28
Sorry, I was a bit inaccurate. The point is that the old logbook is not a FiF logbook but made by a logitPPl application. The logitPPL is able to export the data in xls- and some kind of txt-file so I was wondering if the logitPPL Export and FiF Import could perhaps understand eachothers.
japax
Re: Import Logbook
Postby kitercuda » 05 Apr 2015, 09:14
I think, it is impossible now.
I can publish FIF data format - XML... Data must be coverted to it before importing to FIF.
