slip indicator ASUS fonepad7
Postby phil3854 » 17 Jun 2014, 08:40
hi
slip indicator not work on ASUS fonepad7 android 4.3
a+ :oops:
phil3854
Re: slip indicator ASUS fonepad7
Postby kitercuda » 21 Jun 2014, 13:45
Maybe your sensor need calibration.
Postby pzac » 09 Jul 2014, 12:47
Slip indicator works well with Samsung Galaxy Note 2 but not with Nexus 7 version 2. 3-axis accelerometer testing of both Samsung and Nexus using the application "Accelerometer Monitor" does not show any differences or defaults and both accelerometers are well calibrated on x, y, z axis.
Any ideas to solve this issue?
Regards,
pzac
pzac
Postby kitercuda » 12 Jul 2014, 12:31
Probably your accelerator sensor has SENSOR_STATUS_UNRELIABLE status.
In the next upgrade i will implement new user option in preferences. So you will be able to ignore it and use unreliable sensor.
Postby pzac » 12 Jul 2014, 14:12
According to your answer, I understand that the message "Sensor error, accelerometer sensor unreliable and needs calibration" is elaborated by FIF through the state status provided by Nexus 7.
All people from France with FIF running on Nexus 7 have the same "sensor error", have you any information regarding the criteria used by Nexis 7 to deliver this status because calibration seems to be good?
Regards,
pzac
pzac
