Postby Onuff » 10 Apr 2014, 07:06
the world map is very great and detailed. it should be reduced and put high on the list. as beginners won't find it and won't download 700 mb vie 3g
Postby kitercuda » 10 Apr 2014, 08:47
World is on the top now...
Postby Onuff » 12 Apr 2014, 13:04
Add function GPS over BT.
my brother uses the additional program but they through 1.30 - 2 hour of work are disconnected. the program doesn't conduct satellites. recently I use fif and often loses satellites.)
Postby kitercuda » 13 Apr 2014, 07:03
It will be implemented...
Postby kitercuda » 19 Apr 2014, 18:47
Hi Onuff
- Do you still want to change zoom buttons?
- I just have bougt http://www.gns-gmbh.com/index.php?id=233&L=1. I hope I will connect it to FIF soon :-)
- New aircraft symbol will be at 14.63.
Postby Onuff » 19 Apr 2014, 21:19
magnificent
perfectly
Postby Onuff » 30 May 2014, 20:07
Add calculation of a new point
Postby kitercuda » 01 Jun 2014, 18:21
Does it solve your suggestion? It is not from current position, but using already stored WPT.
1. Open Nav item list
2. Copy some item (long press and select copy)
3. Long press list againg and press Paste with shift.
Postby marpdiaz » 01 Jun 2014, 18:56
useful feature. didnt know that.
Postby kitercuda » 02 Jun 2014, 04:37
Very useful fore creating aerobatics box :-)
