All the world database cycle 1402
Postby kitercuda » 05 Feb 2014, 14:05
Sam has imported all countries to the database. If somebody wants to try it, here is. Unzip and copy to Database folder.
http://www.funair.cz/downloads/worlddatabase/gpsilsvor.zip
Re: All the world database cycle 1402
Postby Onuff » 09 Feb 2014, 19:20
Everything simply super, excellent idea to spread base.
Everything works, but my base was removed.
As to combine them or it is necessary to divide them.
More conveniently
Postby kitercuda » 10 Feb 2014, 08:00
There is not support for using more databses.
I put it here only if somebody wants to try to have half of milion aviation information in his mobile :-)
Postby Onuff » 10 Feb 2014, 19:54
you didn't understand. the base cools. What it to use it with the. to divide
Postby kitercuda » 11 Feb 2014, 09:47
I still do not understand.
Postby Onuff » 11 Feb 2014, 21:45
The is Google)))
Postby Onuff » 09 Mar 2014, 15:02
how to share base on world and user?
Postby kitercuda » 09 Mar 2014, 20:24
I do not understand what you exactly mean.
Postby Onuff » 30 Mar 2014, 13:01
I meant it
Postby kitercuda » 31 Mar 2014, 09:00
If you want to send your WPTs to another pilot, you can use Export/Import (internal format). You can export Folders with subfolders...
