Bugs?
Bugs?
Postby swedflyer » 14 Aug 2013, 19:23
New user of this app. I looks great!
However I seem to have found some bugs.
The GPS calculated AGL value seems odd, 276-112=85?
Also the GPS altitude is off by about 100 feet. It is much more accurate in other GPS apps om my device.
Barometric AGL and ALT makes sense. I walked down to the sea and it read a couple of feet with QNH set from my closest airport. (My home is just by the sea).
When opening the logbook the app hangs showing the "Filling list box" dialogue.
My device is LG Optimus G (E975), Android 4.1.2
Thank you,
Jakob
Microlight pilot in Sweden
swedflyer
Re: Bugs?
Postby kitercuda » 15 Aug 2013, 04:44
GPS altitude is much more accurate than other application, because application corrects raw GPS altitude about geoid altitude (GPS shows WGS84 elipsoid model altitude, but real geoid is not ellipsoid and difference can be more than 300ft). Altitude in Position info was raw GPS altitude, but AGL was counted from corrected GPS altitude...
Repaired :-)
I tried to open Logbook, but without any problem. Can you described me more, what you do, that your application hangs?
Re: Bugs?
Postby swedflyer » 16 Aug 2013, 07:34
kitercuda wrote:I tried to open Logbook, but without any problem. Can you described me more, what you do, that your application hangs?
I open the logbook, and when I select a date (either from or to), it gets stuck, with the spinning "Please wait..." box.
swedflyer
Re: Bugs?
Postby kitercuda » 16 Aug 2013, 08:40
Please can you send me logbook.db file? it is in floder GPS_ILS_VOR/Database.
Re: Bugs?
Postby swedflyer » 16 Aug 2013, 08:50
kitercuda wrote:Please can you send me logbook.db file? it is in floder GPS_ILS_VOR/Database.
Sent!
swedflyer
Re: Bugs?
Postby bitbrusher » 16 Aug 2013, 14:32
Taking advantage of this thread, I found this minor glitch:
Tap "Menu->Tools and Info->Airspaces", what do you read for page's title?
I read "Pilots". Shouldn't it be "Airspaces"?
Bitbrusher
bitbrusher
Re: Bugs?
Postby kitercuda » 16 Aug 2013, 15:20
Re: Bugs?
Postby Onuff » 21 Aug 2013, 07:22
Hi.l am have bug
Re: Bugs?
Postby bitbrusher » 21 Aug 2013, 13:49
This is a bit of topic, but how do you guys take these screen shots??
bitbrusher
bitbrusher
Re: Bugs?
Postby swedflyer » 21 Aug 2013, 14:28
bitbrusher wrote:This is a bit of topic, but how do you guys take these screen shots??
bitbrusher
On newer Android versions (I don't know exactly, but I think since 4.0), hold power button and volume down button at the same time.
swedflyer
