Approach map overlay
Postby pushpull 337 » 23 Jun 2013, 07:57
Hi Petr,
Congratulation for this well done navigator. All looks very good. For my need I am missing the feature to overlay own approach carts and maps in the format GIF or PDF or similar! This cards sometime I am modifying with WIN Paint to better fit with the overlay. The callup buttom for the overlay shut be easy accessible in fligth with selection via nearbe airport directory! PocketFMS has that feature.
What are you think about this theme?
Thank’s
Peter Feil
Cessna 337
pushpull 337
Re: Approach map overlay
Postby kitercuda » 23 Jun 2013, 11:38
If you thing charts associated with the airports (SID, STAR, ILS, VFR charts, etc) look at user guide chapter Airport PDF Information.
This is not used for navigation, only for information...
User guide:
http://funair.cz/domains/funair.cz/forum/viewtopic.php?f=11&t=5356&p=5446#p5446
I already preparded for Czech users pdf of all ICAO airports. Just unzip and copy to GPS_ILS_VOR/pdf
http://www.funair.cz/downloads/worlddatabase/pdf/lk.zip
Postby Onuff » 24 Jun 2013, 19:20
Можно сделать но это трудоемко
Re: Подход наложение данных на карту"
Postby Alekur » 25 Jun 2013, 05:55
Так как нет возможности написать в личку, то спрошу здесь. Onuff Вы военный штурман с Твери?
Alekur
Postby pushpull 337 » 25 Jun 2013, 20:35
Hi Onuff !
That is exactly the picture on the moving map what i need. When there will be overlaid an uploaded APP-route then at a glance you have perfect situation awareness of the approach path wich you only must follow to establishing the plane on the ILS ! The same happens when you approaching with overlaid VFR aerodrome Charts.
I do not understand how you are doing the overlay of the PDF or GIF Charts and the calibration (georeference) of the Chart. The Cards must be stored in some manner within the Airport Folder.
Callup with : OVERLAY (best if own button on Screen)/NEAREST AIRPORT LIST/AIRPORT (LKPR) /OVERLAY LIST (IAC ILS-24, IAC ILS-06, ....). IAC means: Instrument-App.-Chart
What you think?
Peter
pushpull 337
Postby kitercuda » 26 Jun 2013, 11:33
I would like to know too :-)
Postby francojb » 19 Aug 2013, 21:37
Im not sure if this is what you are looking for but try...
viewtopic.php?f=4&t=5430
last comments...
francojb
