MAP creation
MAP creation
Postby francojb » 28 Apr 2013, 00:46
Hi!!!
I know there are programs with which you can georeference charts you have in jpg, pdf, etc formats to use in gps programs. Is there a way to use this kind of georeferenced charts as the map??
Thanks!!!
francojb
Re: MAP creation
Postby kitercuda » 29 Apr 2013, 18:49
Please send me some links to these maps and I will checkt them out.
Re: MAP creation
Postby francojb » 02 May 2013, 13:30
Hi Petr!!
Here is a link of another application where explain how to do it for this app... maybe it could be much clear...
http://forum.naviatorapp.com/viewtopic.php?id=523
I have the chart I geo referenced with the programme mentioned in the link, if you need it I will send it, too...
francojb
Re: MAP creation
Postby kitercuda » 02 May 2013, 16:34
Thanks.
I am testing Android RMaps application for easy map creation. In few days I will post how to do...
Re: MAP creation
Postby francojb » 02 May 2013, 20:35
thank you very much!!!
Best regards
francojb
Re: MAP creation
Postby francojb » 03 May 2013, 00:08
there is also another programme to georeference maps I have used... it´s MAPC2MAPC
I used it to generate a kml map from a jpg for example...
francojb
Re: MAP creation
Postby francojb » 03 May 2013, 14:38
Hi Petr!!!
I found it out...
Using the last programme I mentioned, MAPC2MAPC (http://www.the-thorns.org.uk/mapping/), you can georeference an image, jpg, png or other formats, and then convert it to Mobile Atlas .sqlitedb...
I did it this way... first read "Calibrating a map with google earth" help topic (http://www.the-thorns.org.uk/mapping/GEcalibrate.pdf) , after done that, in FILE menu, choose "Write mobile atlas", "Select atlas" Locus/RMAPS/Galileo sqlite.db, "Zoom levels" 8-11, then OK, and it´s done... then take the file and move it to GPS ILS VOR / maps folder
I hope it helps...
Great app!!!
Thank you!!
Best regards
francojb
Re: MAP creation
Postby Onuff » 03 May 2013, 20:28
