Spain terrain data
Spain terrain data
Postby juanxto » 17 Mar 2013, 11:13
Hello. First of all, congratulations for your app. Really impresive (specially for a one man´s work).
I´m from Spain and when I try to download the associated terrain data (which would correspond approximately to a range between 5º West and 0º Longitude and 40ºN and 45ºN Latitude) the associated file appears as not available for download. Is it a temporary problem or not?. Will it be fixed soon?. Is there any other alternate method to obtain this data (i.e. using the source forge tool you mention on the tutorial).
Thanks in advance.
juanxto
Re: Spain terrain data
Postby kitercuda » 17 Mar 2013, 21:53
Appliction is using srtm data now. There is some places without data. I will implement to use another source. It will be after implemnting vector map. I hope 1-2 months.
Postby juanxto » 18 Mar 2013, 14:06
Ok then. Thanks for the answer!!
juanxto
Postby Ricardo » 28 Aug 2014, 13:14
Hi, I'm testing Flight is Fun and I'm having the same issue, no terrain is shown despite I have the terrain data files,GPS fix, and trying from simmulator too.
Madrid is about 2000 ft MSL and I have a blue background.
Thanks in andvace
Ricardo
Postby Ricardo » 28 Aug 2014, 13:34
Ricardo wrote:Hi, I'm testing Flight is Fun and I'm having the same issue, no terrain is shown despite I have the terrain data files,GPS fix, and trying from simmulator too.
Thanks in andvace
Ok, sorry, my bad, wrong latitude coordinates, everything is working fine
Ricardo
Users browsing this forum: Bing [Bot] and 1 guest
