Define ILS, VOR
Define ILS, VOR
Postby rosdol » 15 Mar 2013, 18:13
Hi, I tried to do this as you did in the Video, however I failed, maybe due to the fact that the menues are a bit different.
I did all the things for LOAV as you did for LKMT, saved it to a kml file and put it into GPS_ILS_VOR Directory on the sd Card
I the went to nav item list
then I was tapping the Screen for nav item list imported the kml file and there was another Directory created (with the place Name i definet in Google earth, the two ils and a vor,
but the symbols do not Show any vor. Also the menues are now very different on the latest Version
can you please revisit your Video and/or explain how to do it ?ß
thanks and regards
rosdol
Re: Define ILS, VOR
Postby kitercuda » 17 Mar 2013, 06:00
Yuo are right. Video is very old, sorry. I will create ne one.
When using Google Earth you can create point or line. Point is imported like WPT, line like RWY. In the past it was VOR and ILS.
If you want to change WPT to VOR long tap at WPT and select Edit WPT. When edit dialog appears, press Item Type button and select VOR.
Changing RWY to ILS is a little bit more difficult, because after pressing RWY and selecting ILS you have to fill runway threshold crossing height and glide slope angle - be careful when filling this values, that GS is clear of terrain and obstacles.
Re: Define ILS, VOR
Postby rosdol » 17 Mar 2013, 11:11
Thanks,
I will try your suggestions.
br
Erik
rosdol
