Create New Airport Folder
Postby MacRob » 30 Jan 2013, 18:21
Hello
I have added a new airport folder for a small airport that is not in the download database.
It is obvious how to name the folder with the airport code (i.e. CNC4)...
... but I can't figure out how to get the line of small descriptive text below the airport code like the ones that were downloaded.
Any instructive advice for this issue?
Will my additional airport(s) be erased when I update with the next download from the database?
FLY IS FUN IS awesome !!!
Rob
MacRob
Re: Create New Airport Folder
Postby kitercuda » 30 Jan 2013, 18:42
1. Create your own navaids, WPTs, airports etc. outside of the folder "World Database". Importing makes changes only inside of "World Database" folder. You can create a lot of folders outside of "World Database".
2. " but I can't figure out how to get the line of small descriptive text below the airport code like the ones that were downloaded. "
Can you post here screenshot and mark on the picture what you need?
Postby MacRob » 30 Jan 2013, 20:05
Here's a screenshot of what I mean:
- CNE3 has "Bearskin Lake" in smaller text under the airport code.
- CNC4 I can't figure out how to get the descriptive smaller text under CNC4
MacRob
Postby kitercuda » 31 Jan 2013, 05:28
Unfortunately it is not possible now, but a put it in my ToDo list
Postby MacRob » 01 Feb 2013, 19:39
Thanks!
MacRob
Postby kitercuda » 10 Feb 2013, 12:42
Done, next upgrade will have it.
Postby MacRob » 20 Feb 2013, 21:29
Hi.
Addition of Notes for new folders works well ...
... but ...
... The new folders get erased when I update nav data from world database.
Is there a way to prevent the new folders, which aren't in the world database, from being erased?
Fly is Fun is the best flying app on my S3 !
Thanks for the great support.
Rob.
MacRob
Postby kitercuda » 21 Feb 2013, 06:17
When updating the world database only folders inside folder "World Database" can be deleted.
Look at attached picture. Folders "Petr WPT" and "Test" were never touched by importing the world nav database.
Postby MacRob » 25 Feb 2013, 16:47
Understood.
Thanks.
MacRob
