Kneeboard
Kneeboard
Postby s57rw » 10 Jan 2013, 17:43
Hi!
Have tested the application in the last days by flying around Slovene coast and works great... As an idea have a suggestion for future versions:
Since having a terrible calligraphy when putting notest on the kneeboard during the flight it would be great if could be added a new screen with kneeboard option. Mainly I mean to register timings like Block on, T/O, LDG, Block off, number and timing if performing T/Gs and start + end totalizer. I guess there is a lot of programming and testing to make it in automatic by monitoring the movements of aircraft by position and altitude from GPS data but if you would have just buttons to press in order to register timings would be great as well.
Regards,
Andrej
s57rw
Re: Kneeboard
Postby kitercuda » 10 Jan 2013, 20:34
Application is saving flight track. After flight (before closing application) you can export it as .kml file and import it to Google Earth to watch it.
I am plannig to improve it in the neare future, add altitudes and possible to watch it in FLY is FUN application.
Re: Kneeboard
Postby s57rw » 11 Jan 2013, 10:28
Ok tnx. Will try it next time in flight.
Regards,
Andrej
s57rw
