Measuring distance
Measuring distance
Postby Pumapilote » 03 Sep 2017, 09:45
I have a suggestion there any possibility to measure the distance between any points in the maps also during flight
Not between you position and other points but between two différents points
Have nice day
Pumapilote
Re: Measuring distance
Postby Tonio » 06 Sep 2017, 20:30
I use an old method, put my fingers on the map and compare with the scale, that is indicated
Precision is not metric, but this is more than enough for me
And it forces me doing mental exercise…
Postby kitercuda » 10 Sep 2017, 10:40
Do you haver suggestion, how to do it?
When you tap map by two fingers, it unlocks the map. Maybe display small window at the top with distance?
Postby Pumapilote » 10 Sep 2017, 20:13
Yes it's a great idea if you can make it.
Pumapilote
Postby marpdiaz » 11 Sep 2017, 16:47
I also measure distances on map by eye evaluation, using the displayed map scale.
I guess that the distance precision achieved by double finger touch (unless you choose already displayed items) would be similar to eye scaling.
cheers,
Postby kitercuda » 11 Sep 2017, 17:10
Today I have started to implement it :-)
Postby kitercuda » 11 Sep 2017, 20:36
Version 20.10 will have it...
Postby Pumapilote » 14 Sep 2017, 21:38
Good job
Tanks for your fast reply and good luck
Pumapilote
