Waypoint Altitude Marks on Vertical Display
Postby schoma » 08 Jun 2016, 13:40
Hi Fly is Fun-Team
At the Moment, is shown in the Verikal view the planned height of the flight plan as a down arrow.
Unfortunately, we can specify no Minimum or Maximum altitudes in the flight plan. On the Attached JPG, a proposal is presented.
1). Waypoint Maximum 5000 ft
2). Waypoint Minimum 10'000 ft
3). Waypoint 7500 ft (Standard)
It would be helpful if this feature would be implemented.
(New Attribute on .gir example: <wpAltitudeMinMax> )
Still a small question. In the vertical view the flight trend line works only in the Simulator Mode or with an external Barometer sensor and not with the GPS? The line Shows a straight, while my mechanical vario in the aircraft Show -2000 ft/min (120 kts)
Thank You
schoma
Re: Waypoint Altitude Marks on Vertical Display
Postby no-bat » 09 Jun 2016, 13:33
This line works only with internal or external barometer sensor. I use Samsung Note 4.
