Postby Onuff » 01 Sep 2013, 18:42
Petr logbook super.
Can you made reverse route..?
Postby kitercuda » 02 Sep 2013, 06:20
Application enables import route from KML or GPX files. So try to convert to these formats first...
Postby Onuff » 05 Sep 2013, 05:03
Route back in menu.
Postby kitercuda » 05 Sep 2013, 07:46
You can invert wpts when editing route.
Next upg ill improve routes. I just finished route summary: counting fuel and time n depending of wind.
Postby Onuff » 14 Sep 2013, 20:47
kitercuda wrote:OK, I will add Sx if you need it :-)
Hi Peter
All your updatings of the program super
When you make Sx?
Postby kitercuda » 15 Sep 2013, 05:36
Next upgrade :-)
Postby kitercuda » 17 Sep 2013, 04:47
Why the abbreviation is SX?
SX - how to call it?
I will implent it when I will know this (I did not find information at the web sites)
Postby pilot55 » 17 Sep 2013, 10:09
Hello Peter
I very much like your program
But I can't find in it Rossii.Kotorye's small airfields is in the vprf.kmz file
Whether it is possible to integrate this file into your program?
pilot55
Postby kitercuda » 17 Sep 2013, 10:55
It is easy:
1. Rename file to vprf.kmz.zip
2. Unzip file (unzipped file will be something like this doc.kml)
3 import unzipped file
Postby Onuff » 17 Sep 2013, 20:17
kitercuda wrote:Why the abbreviation is SX?
Dme -distance from a plane beam to a point
