Auto switch Waypoints- switch range
Postby pete2052 » 10 Aug 2013, 16:20
When following a route, the auto switch to the next waypoint seems to happen at a range of 1nm or less from the current waypoint
If you cut the corner outside this range auto switch doesn't happen.
Could this range be made user adjustable please?
Pete
pete2052
Re: Auto switch Waypoints- switch range
Postby kitercuda » 11 Aug 2013, 16:43
Algorithm for switching WPTs is more complicated than checking distance only.
One of valures is the max distance from WPT, where is possible apply switching algorithm. This value can be adjustable at preferences.
Postby pete2052 » 11 Aug 2013, 18:20
Ok, thanks, sounds just the thing, but where is the setting in preferences?
Do you mean "Max nearest distance" this is already set at 100nm.
Pete
pete2052
Postby kitercuda » 12 Aug 2013, 09:27
It is not in prefereces now. Next upgrade will have it and it will be called Max distance for switching WPT
Max nearest distance is max distance for searching the nearest objects...
Postby pete2052 » 12 Aug 2013, 11:42
Ah, sorry I misunderstood!
I think that will be a great improvement, to be able to adjust the autoswitch sensitivity .
Many thanks for a great App.
Pete
pete2052
Postby Onuff » 12 Aug 2013, 16:47
Very good.
Postby pete2052 » 15 Aug 2013, 14:27
That was a quick upgrade! Thanks!
For info: "Always switching DME" has a typo error, I think the last option should be 1500ft, not 150ft...... Could these options be made bigger say up to 2nm?
Pete
pete2052
Postby kitercuda » 15 Aug 2013, 15:19
Yes, it must be 1500 ft :-)
Postby pete2052 » 15 Aug 2013, 16:46
And could these options be made bigger...... say up to 2nm?
pete2052
Postby kitercuda » 15 Aug 2013, 21:50
Yes, next upgrade...
