Different color for D,R,P zones
Postby Ricardo » 05 Sep 2014, 09:26
Hi, I think the D,R,P zones demarcation should be on different color than airspaces, for example, Jeppesen chart represent these areas in purple and a pattern of inclined lines instead of a solid line.
Ricardo
Re: Different color for D,R,P zones
Postby kitercuda » 05 Sep 2014, 18:37
In FIF database there are D.R.P. zones?
Postby Ricardo » 05 Sep 2014, 19:31
Well, I can't tell you if the airspace file that come with the original database has DRP zones. I replaced with one more upated ( spanish airspace, I mean) and I saw thhe same representation for airspace and that zones
Ricardo
Postby Ricardo » 12 Nov 2014, 11:33
Hi, looking into the openair specification and I see the SP command.
From the specification:
"SP style, width, red, green, blue ; Selects Pen (border) to be used in drawing
PEN STYLES in SP command:
SOLID 0
DASH 1
NULL (transparent=no border displayed) 5
Example: for a 1 pixel wide, dashed, light gray pen use: SP 0,1,192,192,192"
http://www.winpilot.com/usersguide/userairspace.asp
I think FiF is not reading that command for airspaces, I'm right? if that's the case, can you make FiF read and follow the SP command directives?
Ricardo
Postby kitercuda » 13 Nov 2014, 05:48
FIF is running under OPEN GL. There are a little bit jungle, because there are different versions of OPEN GL. Some of them support some functions, some of them not. There are not pen commands...
Postby Ricardo » 13 Nov 2014, 08:13
Ok, I understand. Any chance to change airspaces colors via preferences menu?
Ricardo
Postby kitercuda » 13 Nov 2014, 11:03
I am now thinking about it how to do it es simply as possible.
Postby Ricardo » 20 Nov 2014, 14:50
Well, you dit it, thank you so much
Ricardo
Users browsing this forum: Baidu [Spider] and 1 guest
