Second needle to select other Waypoint
Postby francojb » 29 Jul 2013, 15:28
Hi Petr!!! How are you!?!?
First of all I have to say again this is a great app, best I have used!!
I was wondering if it will be the possibility to to add a second needle, as the blue one, to select a second waypoint, and may be with the possibility of switching the information shown from one waypoint to the other.
It will be very usefull when you are navigating a route and, for example, you still have to give position information to ATC refering the passed waypoint...
I don´t know if the app already has a function to solve this situation...
Thank you very much in advance!!!
francojb
Re: Second needle to select other Waypoint
Postby kitercuda » 30 Jul 2013, 21:09
Hi, tomorrow I am going to fly to EAAC. I will be back after 11.8
I put it to my long ToDo list. When I will be back, I must finish LogBook - a lot of work. Then I will be able to work on users requests.
Postby Laotse » 11 Dec 2013, 07:49
Dear all,
maybe a splitting it up like in "Airnav pro" application would be interesting:
1.) Having e.g. a route which you follow, getting the standard display parameters
2.) Having the possibility to put another VOR or any WP on the HSI (needle) for ATC reporting purpose.
Actually that would be a need feature.
Cheers,
Laotse
Laotse
Postby kitercuda » 11 Dec 2013, 08:46
Please upload here screenshot, what you exactly mean.
Now is possible to see only direction to second WPT- like NDB...
Postby francojb » 23 Dec 2013, 15:12
Hi Petr!!!
Nav 2 WPT arrowhead is very good!! Could it be possible to have the tail of the arrow?? and a simple way to switch from Nav 1 to Nav 2 so we can have Nav 2 information, too, as DME, ETE, etc...
It would be great!!
Well... thanks a lot for every update!! one better from the other!!!
Merry Christmas!!
And I wish you and we all have a great 2014!!
francojb
Postby kitercuda » 23 Dec 2013, 19:13
Nav2: tail arrow, DME etc is on my todo list.
Merry Christmas and happy New year :-)
Postby francojb » 26 Dec 2013, 14:30
Great!! thank you very much!!!
francojb
Postby Angelo » 06 Jan 2014, 22:07
How can the second arrow be displayed? I could not find this in the manual.
Angelo
Postby kitercuda » 07 Jan 2014, 12:59
Long tap at the nav item, then select Navigate 2.
Postby francojb » 07 Jan 2014, 14:03
Thank you very much Petr!!!
The whole 2nd arrow is a great help!!
francojb
