DATA FIELD OPTIONS
DATA FIELD OPTIONS
Postby pzac » 20 Apr 2013, 13:05
Bonjour from France,
Day after day, I appreciate Fly is Fun which is an excellent GPS Navigation Tool.
Would it be difficult to implement in App Settings/Customize Screen the following Data Fields:
1- Distance (Destination): The distance to the destination waypoint in the Active Flight Plan
(Distance to next waypoint is already implemented)
2- Estimated Time En Route (Destination): the estimated time it takes to reach the destination waypoint from the present position, based upon current ground speed
(Estimated Time En Route to reach next waypoint is already implemented)
Best Regards,
pzac
Re: DATA FIELD OPTIONS
Postby kitercuda » 21 Apr 2013, 13:19
I think it can be added.
Curren version has this information - maybe it is a little bit hidden.
After activate activate route navigation:
- tap at aircraft symbol inside the compass rose or
- tap at name of route and select Route
Is it enough for you?
Postby pzac » 23 Apr 2013, 09:12
HI,
Many thanks for your answer.
I agree with you, the two requested informations are available in the 'Active Route' screen. Regarding ETA, I did a mistake because this information is also available as an option in Data Fields of the navigation screens. In the same way, would it be possible to have, as an option, a Data Field related to Distance to Destination ?
Cheers,
pzac
pzac
Postby kitercuda » 23 Apr 2013, 11:34
OK, I will add it to my ToDo list :-)
Postby pzac » 23 Apr 2013, 16:40
Thank You
pzac
pzac
Postby pzac » 03 Jun 2013, 05:26
Many thanks for the implementation of these features in the release 11.41
Best regards,
pzac
pzac
