Readability
Readability
Postby Breitling » 12 Feb 2013, 23:55
Yes, I know it is a small "cosmetic" suggestion, but don't you think it improves readability?
- Make the figures on the speed and altitude strips to have the same background colour as the strip colour.
- Dont show the map image on the upper strips sections.
- Maybe make the strip figures font a bit smaller.
- Make a thin border on the actual speed and altitude windows.
See attached images. First one is the original, second one is what I propose you.
Thanks Petr.
Original
Proposed
Breitling
Re: Readability
Postby kitercuda » 14 Feb 2013, 11:29
Good, thanks - I will implement it. Next upgrade wil have it.
Re: Readability
Postby Breitling » 26 Feb 2013, 08:13
I've seen corrected the second list item from the first post. Is not possible to check the otrer items in future upgrades?
Breitling
Re: Readability
Postby kitercuda » 26 Feb 2013, 09:09
Yes, they are in my todo - list. I prefer to quick finish topo chart s. But I have to test it, if it is really better...
Edit:
Done, next upgrade will have it.
Re: Readability
Postby Breitling » 07 Mar 2013, 20:34
Great now ! I miss just the first item (same gray background on strip numbers) but it looks much better now. Thanks Petr.
I love the north up map option too.
Breitling
Re: Readability
Postby kitercuda » 08 Mar 2013, 07:15
Thanks for your suggestion...
Re: Readability
Postby marpdiaz » 22 Jul 2013, 20:29
Another suggestion for a small change:
The current labels for airports may contain IATA codes, when available, as well as ICAO 4 digit codes.
When both are present the airport label gets too large, easily overlapping other important info. This
gets particularly bad when using small display devices.
I suggest to remove the IATA codes from depiction, leaving only the ICAO codes on display.
cheers,
Re: Readability
Postby kitercuda » 23 Jul 2013, 04:48
You are right, IATA is useless information.
Next upgrade will solve it.
