"Distance to Height"
This can be used primarily to show/determine the glide distance from your present height to a user selectable height, (or by default , sea level) or could also be used to show the distance to a user set, climb height (which would use the same formulae)
We have the sensors built in to most of our android devices for this to be calculated.
Using the formulae:
(Present height - desired height) X Ground speed MPH
divided by
Rate of decent or climb (ft/min) x 60.
This box would be continually showing the distance to this height and could show "--" or something like when you are not decending or climbing (as it would go to a distance up to infinity ....and beyond
