On Menues...
On Menues...
Postby rosdol » 20 Mar 2013, 11:05
Hi, first of all let me thank you for this amazing Software. Almost as my Garmin G1000 in my cockpit.
I have on suggestion for the time being - on menues.
Can you please consider this change: when you want to work on an item out of a menue and press the back button you do not fall back to the menue you rather fall back to the application and one has to look for the menue again to select other actions from the same menue
thanks and regards
Erik
rosdol
Re: On Menues...
Postby kitercuda » 21 Mar 2013, 09:58
Application uses Android menu. So I do not know now how to solve this. I try to check it out.
