Estonian VFR map from PDF to the app
Postby jkaljundi » 05 Jun 2015, 10:51
Can anyone help with getting the Estonian VFR map from PDF format to be inside the Fly Is Fun app?
The map itself is in PDF format at https://aim.eans.ee/index.php?option=co ... 19&lang=en
I know in the future it will also be released as GeoTIFF, but not yet. So the confersion would need to be from PDF. Any pointers on exact steps to get it from PDF to be in the app format?
jkaljundi
Re: Estonian VFR map from PDF to the app
Postby Tonio » 14 Nov 2015, 00:06
Please find enclose 3 links
1 - Estonia in RMaps SQlite format generated with your PDF file to use with FIF
https://www.dropbox.com/s/zjw2j2orfvakn ... itedb?dl=0
1 - Estonia in kmz format generated with your PDF file to use withFIF
https://www.dropbox.com/s/qferl26nfljmo ... 5.kmz?dl=0
1 - Estonia in RMaps SQlite format generated using Opentopomap to use with FIF
https://www.dropbox.com/s/nc9e2l91zitxn ... itedb?dl=0
I hope this will help you
Antoine
Postby jkaljundi » 21 Nov 2015, 11:58
Wow, great! Thank you so much Antoine! 8-) You rock!
jkaljundi
