Hi, in Austria we had Amemdement 114 im May 2013, since then the Chart in flyis fun has not been updated.
With this I want to make you Aware of changes in the LOAV (Bad Vöslau Airport) Airport about These changes with the question if you will be able to Change the map for Austria accordingly:
To summarize: VRep "O" has been removed as vell as AV002, "Z" and "N".
Renamed "H" to "U"
Slightly displaced Vrep "E" due to cloud breaker from MOVOS to AV805 (which is a new Vrep)
Here are the Details (whay is attaching a PDF file impossible ?????)
Reporting point A (N475826 E0161445)
Reporting point B (N475734 E0161614)
Reporting Point E (N475639 E0161801)
Reporting point G (N475904 E0161910)
Reporting point K (N475918 E0161324)
Reporting point L (N475606 E0161239)
Reporting point S (N475451 E0161525)
Reporting point T (N475804 E0161018)
Reporting point U (N480046 E0160952)
Reporting point W (N475936 E0161153)
Reporting point X (N480000 E0161756)
Reporting point AV805 (N475643 E0161847)
best regards and all the best for 2014
Erik Rosdol
