Hi Petr.
What is the VR logging and display criteria for fif?
If I open fif on the ground can I see active vr users displayed anywhere on the map if I move the map around? What is the criteria you use for transmitting my position..... logbook speed setting? I set my vr history to 12hrs and did pickup a plane from the morning ok. Many thanks Peter G.
