Way Points Storage
Way Points Storage
Postby pzac » 06 Jul 2013, 20:33
With the previous releases it was possible to create WPTs from the map and to store them in a specific directory defined by the user. In my case, I have created a directory named "User's WPTs" where I stored these WPTs. This directory is located at the same level that Airports, Navaids, WPTs directories.
It seems that with the last releases this feature is no more available. User's WPTS can be created from the map but are always stored at the same level that the World Database directory. Using Export command, it is possible to transfer these WPTs in the User's WPTs directory, but this operation requires a lot of commands which were not necessary before. Perhaps I am wrong in the use of the GPS tool ?
In any case, congratulations for this software which is more and more efficient.
pzac
pzac
Re: Way Points Storage
Postby kitercuda » 07 Jul 2013, 18:59
I am planing storing new "long tap WPTs" to a specific directory.
Now it is not possible, but you can move them:
- Long tap at WPT ant naw item list
- Select Copy
- Open desired directory
- Long tap to any item
- Select Paste
Postby pzac » 08 Jul 2013, 06:17
Many thanks,
This way is more simple than export/import and is ok for me.
Regards,
pzac
pzac
