Delete fields
Re: Delete fields
Postby kitercuda » 22 Dec 2012, 21:24
Create separate folder for each file before import (Menu/Add folder) in Nav item list. Import each gpx file to separate folder.
Then you can delete folder with all items inside...
Re: Delete fields
Postby Eliseo » 24 Dec 2012, 09:27
Ok. Perfect, thanks.
Attention:
In Google Play tells me (Nexus 7)
This item (Fly & Fun) is not compatible with your device
Eliseo
Re: Delete fields
Postby kitercuda » 26 Dec 2012, 16:31
Thanks for info. I must find out why...
If you need it, download it here ant install manually:
viewforum.php?f=7
