Delete fields
Delete fields
Postby Eliseo » 12 Nov 2012, 21:17
I can not delete multiple fields at once.
Help please.
Eliseo
Eliseo
Re: Delete fields
Postby kitercuda » 13 Nov 2012, 13:48
Fields from where?
Can you post some screenshot?
Re: Delete fields
Postby Eliseo » 13 Nov 2012, 15:50
kitercuda wrote:Fields from where?
Maybe I explained wrong
I do not know how to delete several VORs
or the entire list off VORs.
Vors 2012.png (80.72 KiB) Viewed 27313 times
Eliseo
Re: Delete fields
Postby kitercuda » 13 Nov 2012, 17:11
Long press at desired VOR - and contextr menu will appear. Then select Delete VOR. Look at the picture.
You can delete whole folder: long press at the folder and then select Delete folder.
Re: Delete fields
Postby Eliseo » 13 Nov 2012, 19:25
Hello Kitercuda
I do not want to delete the folder, I want to delete all VORs
But not the ILS.
Before they could do, but not now.
If waypionts over again,
VORs are duplicated.
in previous updates, it was possible to delete
multiples VORs or all they.
Eliseo
Re: Delete fields
Postby kitercuda » 14 Nov 2012, 06:29
How you duplicate VORs? Can you describe it?
In previous version was possible only "Delete al below".
I will add in the next upgrade "Delete al" - First you make some some selection and then you can delete all...
When you open Nav item list, try to fill "Text to find" and then long press "Find" button (about 1 second).
Re: Delete fields
Postby Eliseo » 15 Nov 2012, 09:05
I can not select multiple VORs.
¿What are those symbols on the right of the vors?
Look at my picture.
Eliseo
Re: Delete fields
Postby kitercuda » 15 Nov 2012, 18:40
Today i uploaded new user guide. I explain there what is it.
http://www.funair.cz/downloads/manuals/gpsilsvor.pdf
Re: Delete fields
Postby Eliseo » 05 Dec 2012, 14:44
I'm sorry, but you're right ... airfields not duplicated when importing the same folder.
I have imported 3 folders and now I want eliminat airports in one of the folders.
How I can do?
Eliseo
Re: Delete fields
Postby Eliseo » 21 Dec 2012, 16:21
Let me explain to you exactly my problem: the problem is related with my waypoints. For example, I have in sdcard/gps_ils_vor/Spain1.gpx; SpainULM.gpx; France1.gpx ... . I import two folders of them, Spain1 and SpaninULM. But when I want to later delete only one of these folders, for example SpainULM, I can't delete the waypionts of SpainULM. How can I remove these waypoints, that is, how can I delete the whole waypoints of SpainULM, and not one by one?
Thanks :D
Eliseo
