Timer
Re: Timer
Postby sonntagc » 27 Oct 2017, 22:33
Hi.
The timer function still would be great.
To remember to control the fuel tank selection... For example
Start the timer
Select an action - alert or text message that will be displayed
Time h:mm
Start
When time passed - window with text message and option delete or repeat.
That would be great
Thanks a lot
Christian
sonntagc
Re: Timer
Postby kitercuda » 30 Dec 2017, 18:44
It is my 2018 plan :-)
Re: Timer
Postby Viking » 30 Dec 2017, 23:12
sonntagc wrote:Hi.
Christian
Hi Christian,
In Screen customizing, if you have a "UTC or LT time cadran", you have an alarm as you want (text, beep and you can repeat)
Jean-Pierre.
Viking
Re: Timer
Postby Tonio » 01 Jan 2018, 08:30
What about using default android watch/ timer/ alarm application beside FIF
Each time alarms pop-up, instead of closing it, click on restart launch it again
Re: Timer
Postby kitercuda » 16 Jan 2018, 14:58
At my ToDo list is timer with a lot of functions. It is only question of priority/time.
For example it could be activated after take-off, warning when reaching some altitude etc.
