Map of Israel
Map of Israel
Postby oodimen » 16 Apr 2019, 12:44
Hello. Do you have a map of Israel for download and use in the applivation? Thanks much. Best regards. Oodi
oodimen
Re: Map of Israel
Postby Tonio » 19 Apr 2019, 15:17
Hi Oodi
I tried generating a map for you, but, here in Africa I have a poor Internet connection
To create a missing map, you need to use applications as Mobac (easy to use), SAS Planet more difficult, Terra Incognita and have a good Internet connection
Within the selected applicatiuon
- Chose RMAPSqlite as export format
- Select the Internet source map ex OSM / Open Street Map
- Then the area
The application will then generate the map, but you need a good Internet connection
Then installation procedure for FIF is described on chapter 21 of the userguide
Any additional maps are then welcomed
Have fun
Re: Map of Israel
Postby oodimen » 10 May 2019, 15:37
Thanks much.
oodimen
